Volume normalization--is it there?
  • chas88
    I have the converter. I have codecs. I have the CD writer, and I have the PowerPack. I burned nine versions of the same tune on one CD, all by different artists from different sources. Volume varies from one tune to the next. Is volumne normalization an auto-feature, because I never spotted any reference to it during the burn process? If it is, it's not working. Thanks for any help.
  • drspy00
    • 104
    Re: Volume normalization--is it there?
    You can volumise when converting, its a little checkbox, you cant miss it.
      • 46232
      Or for the Power Pack it is: select audio file in explorer >> rigth click >> convert to >> select Audio CD then click 'Power Pack DSP'.
