.m3u Read Problem w/ Win2k Pro
  • Mixwell
    I used to use dBpowerAMP v.5 and was having a problem where when I moused over some .m3u playlist files, it crashes explorer instead of listing the files that the playlist should play. I upgraded to v.8d hoping that that would fix the problem, and it still crashes explorer.exe if I mouse over particular .m3u files, though it lists others correctly. I've traced it down to the "Popup Info Tips In Explorer" option in the dB configuration because when I turn it off, I have no problem mousing over any .m3u files, however, I like the option of seeing what files the playlist is going to play, so I wonder if there's any way of fixing this, or if it has happened to any other user. Thanks.
    Please send one of these m3u files to [email protected]
    • Mixwell
      Thanks, email sent!
