Release 2 does not release my keyboard
  • QuadraDuce
    • Jun 2002
    • 16
    Prvious to Release 2 when I would stop using dbAmp my multimedia keys would go back to their normal assignments. With Release 2 my volume and mute keys do not function once I close dbAmp. At minimum I need to Log off and back on.
    Any suggestions?
    QD
    Dell Dimension w/ XP Pro and Miscrosoft Natural Pro Keyboard.
  • donny
    • Oct 2002
    • 761
    Re: Release 2 does not release my keyboard
    Well if you assign diferent keys to dAP, then I think it will realease those...
    • QuadraDuce
      • Jun 2002
      • 16
      A little more info.
      If I do not use my volume/mute keys when dbpoweramp is running, then once closed - the keys work as expected for all other programs. However, if I DO use the volume/mute keys while playing dbpoweramp (vol/mute works fine), then when I close the program -- my keys still are unfuctional.
      All keys are unassigned via the keyboard control.
      Hot keys are not assigned via any other software.
      -QD
        You have the option of deleting 'dAPKeyControl.dll' to disable such functions.
        • QuadraDuce
          • Jun 2002
          • 16
          Thanks!
          That did it!
          May I say that for a basically free software package I have never seen responses so quickly posted and accurately too!
          db-stuff still remains my favorite!
          -QD
            Really I should investigate it...
              I was having the same problem, only I'm using release 3 b5 and as suggested went to delete the dapkeycontrol dll while this problem was occuring (ie. i had run powerAMP, then closed it down). Windows (2000) complained that "the specified is being used by Windows".
              Hope this helps....
                I had the same problem of loosing functionality of the mm keys after using them with dAP. Renamed dAPKeyControl.dll and the problem is solved. I can use the volume, etc., in dAP as well as other apps now with no problem. Running XP Pro on an Athlon XP system with nForce 2 chipset if that will help in any way...
                  Oh, also, that was with r3b5...forgot to mention that...
                    I am going to change that - should be easy to fix.
