Player Problem
  • rickytin
    • Nov 2002
    Player Problem
    Each time I open the player it give me This massage problem "The procedure entry point WMCreateSyncReader could not be located in the dynamic link library WMVCore.DLL"
    What can be the problem.
    Ricky Dominguez
  • donny
    • Oct 2002
    • 761
    Re: Player Problem
    Have you installed WMA codec for dAP? If you have try uninstalling it, and see if the problem remains... If it's solved then try reinstaling (maybe the old install was faulty) or maybe there are some more problems on your PC...
    • rickytin
      • Nov 2002
      Re: Player Problem
      Donny thanks for the tip it work.
      Ricky Dominguez
