Freedb not working, freezes DAP
  • Ralph124C41
    • Feb 2004
    Hello,
    I cannot get the audio cd input to connect successfully to Freedb. Most of the time if I try to use the options panel the whole program will stop working and I will get a message that CDgrab.exe is not working.
    I have uninstalled and reinstalled the latest 10.1 version twice. I have also tried the new 10beta8 version and still nothing works on Freedb. When I have been able to use the options I have used both the defuct Freedb setting plus the United States one. Again, nothing works. I use a firewall (ZoneAlarm free) and I have turned it off and on and still nothing works. I use a dial-up modem without a proxy and I even tried one suggestion to manually set a free proxy setting but -- still -- nothing works.
    I would like to use the program but I don't want to type in all the info from my albums.
    Any help will be appreciated.
    Re: Freedb not working, freezes DAP
    Do you have a firewall? such as ZoneAlarm, or Windows XP built in Firewall?
