Conversion doesn´t work on certain CD´s
  • Bill50x
    • Feb 2004
    Suddenly conversion on cda-files doesn´t work - even on my own homeburned cd´s. Anyone knows a reason why this have stopped working? It worked fine until 2 weeks ago. When I open the "dMC Audio CD Input" it just shows one file with 0 bits, instead of the actual content. So do Foobar, by the way. It is not th case on all CD´s, just some.
    Anyone know why?
    Regards / Bjarne
    Re: Conversion doesn´t work on certain CD´s
    Anyone know why?
    Regards / Bjarne
    Found out that version 10 is the fault. With version 9 everything works fine, but when installing v10, the conversation from cda´s don´t work anymore. It seems that the ASPI-thing is screwed up.......
      Shouldn't be, R10 or R9 do not touch ASPI, rather they just use it, perhaps it is where you have R10 installed? anyway check Support >> Audio CD Input there are ASPI checking and update programs.
