Buzzing sounds when Dbpoweramp paused
  • ferris209
    • Oct 2003
    • 181
    Howdy, whenever I have my Dbpoweramp Audio Player puased on a song and I click the back or forward buttons in Explorer instead of the click sound, I get a buzz sound. I've notcied that any time I have a song paused, any other sounds are buzzes. I have Soundblaster Audigy Platnium Pro and all the software. I've found that it works on both DirectX and Waveout. I dunno what the cuase is or what I can do different.
    "It's better to have it and not need it than to need it and not have it!" - John Wayne
    [URL=http://www.powersnipe.com?upartner=21095]Powersnipe is the best for Ebay![/URL]
  • donny
    • Oct 2002
    • 761
    Re: Buzzing sounds when Dbpoweramp paused
    well I think that this is something that is quite normal whatever player you are using if the speakears are turned up high
    what you hear is (if I'm right) is the sound of electrical power ( the 50Hz sound) which is normal when there is no other input... or there is somekind of electric "noise" that the cables are picking up and sending to the speakers...
    what speakers are you using and how long are the cables... anyway anything powerfull should have noise :(
    • ferris209
      • Oct 2003
      • 181
      Nah, that ain't it, the other sounds are entirely phased out by the buzzing, it's not just a slight buzz, I think it is some sort of software or driver mishap.
        • 46373
        Check the drivers.
        • ferris209
          • Oct 2003
          • 181
          What should I check for?
            • 46373
            Any new version.
            • ferris209
              • Oct 2003
              • 181
              I checked the drivers and found that I needed a new version, I downloaded, installed and that didn't solve the problem. I dunno, I guess I'll live with the buzzes
              • donny
                • Oct 2002
                • 761
                Have you checked the cables - maybe they are damged or they have some kind of an interference.....
                • ferris209
                  • Oct 2003
                  • 181
                  No, it only happens when the player is paused and other sounds are to be played such as clicks on the back and forward arrows on internet explorer, and stuff like that. I can't figure it out except I think it is some sort of program or driver flaw.
