DbPowerAmp 'Hijacks' Volume Control
  • Moosey
    Hello. I use a Dell Inspirion 8500 laptop (and please dont comment on dell, ive heard enough bad things about them, ok?) and I recently installed DbPowerAmp. My problem: I have to volume buttons on my keyboard, used for adjusting computer volume, but when I installed DbPowerAmp, these didnt seem to adjust the computer volume, but the volume of DbPowerAmp ONLY. After I uninstalled and rebooted, it worked again. Now, I would really like to try out DbPowerAmp, but if I cannot solve this problem, it will just go to my Recycle Bin. Any Help?
    Many Thanks.
    Re: DbPowerAmp 'Hijacks' Volume Control
    I don't see a way around it short of an option, if Windows Media Player is running it will do the same as dAP.
    • Moosey
      Well, strange things is, Media Player doesnt do it. And the volume controls are dodgy even when DbPowerAmp is off, they only revert back to normal once i uninstall it and reboot.
      Well.. Im if theres no way around... oh well... I'm still a huge fan of the Music Converter.
      • donny
        • Oct 2002
        • 761
        did you try to put dap output to DirectX instead of Wave? And also check the keyboard shoutcuts ....
