some small bugs / thanks
  • X={music}=X
    • Jan 2004
    (using latest beta, w2k, athlon 2k)
    thanks
    * the program seems a lot faster in responsiveness
    * MMC: the "select same" is great!
    bugz
    * In MMC, the number of times a track is played is not updated for tracks less then 5 seconds (eg Farmers Manual / fsck . it always stays as null.
    * not sure if this is a bug, but in MMC, 3rd button click and then scroll (like in most M$ appz) does not work.
    * when windoze task bar is vertical on left, right clicking on prev played "<<" brings up the flying-in screen as normal, but then it freaks out when trying to move it or click X to close. its like it doesn't know where you are actually clicking in the window. moving task bar to bottom, this does not occur.
  • donny
    • Oct 2002
    • 761
    Re: some small bugs / thanks
    for the 5 sec thing - this is how much of the song must play before it is considered "played" - so that songs that popup often and you just skip them aren't counted. So this is not a bug...
    scrolling in MMC doesn't work cause it isn't using the windows standard scrolling system (it is a custom one), so windows can't scroll it always...
    how do you mean task bar vertical left ? Do you mean tha start menu, tray and stuff? I'm using them this way for a long time and i don't have any problems... (I'm using XP)
