Questions about skin Designer Part II
  • The Byte Healer
    a) When I say two events I mean two Functions see N-LOG skin.
    The play button turn on the display lights and also appears the symbol of the <PLAY> button.
    WHAT IS THE TRICK?
    b) If you use a Hi-Fi Skin like me the STOP button is a must.
    c) I can't appear a second skin window (it has only a Total label) in FRONT of the main skin it is appeared always behind.
    How can I do it?
    And don't forget that Iam new designer and I need details.
  • donny
    • Oct 2002
    • 761
    Re: Questions about skin Designer Part II
    c) Z-order (like layers in Photoshop) - the smaller the Z-order is the hihger the part gets - so set the main to (for example) 5 and the total part to 1. It should work
    b) use "clear" instead of toggle (although it probably will work the same.
    a) in N-Log the lights window is set to "show while : dapplaying" or something like that.
    sometimes you should just load the skin you are inspecting into skin designer (if you destroy sometihing re-install) and see how it works. You can learn a lot
    and feel free to ask for more details
      Thanks for the answer Donny,
      I use already the clear method for the STOP button, but if you hit it twice became a play button,also I use a repeat button except the random and I don't see anything like this.
      Let's do it some one.
      I have a small problem with the PLAY button, when you push it to play it goes first not playing and then stay at the play position and vice versa.
      • donny
        • Oct 2002
        • 761
        Take a look at Stereo Ga Ga - you should find most of the answers you need.
          • 46147
          As donny says, just load any existing Skin to look how they do it.
            BUT I can not load any existing skin except the skins from the Skin Designer.
            How can I do it?.
              • 46147
              If you browse to where dap is installed then change into skins you can load any of those skins, even the defualt.
              • donny
                • Oct 2002
                • 761
                you can practically load any skin by selecting the "dBPowerAmp.dbskin" file in it's directory....
                  A big THANK to all of you.
                  Now I can load any skin to the skin designer and many queries been answered with this way.
