Playlist does'nt work on NT 4
  • Denis
    I have installed DAP on an XP computer (works well) and on a
    NT 4 computer (portable DELL).
    On NT4, the playlist does not work : dap play one song then hang when it try to play the next (with or without the crossfade mode).
    Is the uncompatibily with NT 4 ?
    Re: Playlist does'nt work on NT 4
    No shouldn't be, when it hangs can you still move the Amp Window around?
    • Denis
      Yes,
      in fact he does not play the next item of the playlist.
      but if I double click, it run again. (it's not really hang, the dap
      do nothing).
      I have notice that, if I define 20 seconds in crossfade, the dap
      display many titles of the playlist very quickly, then do nothing.
      So it's only a "one shot play". instead of playing a complete play list.
        Switch off the crossfade and any gapless also try options menu >> AMP >> set the output to direct x.
