Questions about skin Design
  • The Byte Healer
    Hi
    I am new skin Designer and that's why I have some questions to the experts.
    a)Let's say that I want the <PLAY> button to do two events the same time, except the default, to turn on the display lights.
    Then I want to turn off the lights with the <STOP> button, and
    generaly when the music stop playing.
    By the way, I don't see any event about this button and I use it in my skin.
    b)When a button is pressed I want to see with the same LABEL the total
    time, and the played time when it is de-pressed, and more complicated is to turn on two different leds-labels each one for each time.
    My email is: [email protected]
    Thank you
    Re: Questions about skin Design
    Your play button should toggle the event evtdBPlay,
    I will note down to add a new function to the skin designer that will show images only whilst playing. i should be working on this in about 4 weeks.
    • donny
      • Oct 2002
      • 761
      In dAP there is "playing" and "not playing" and you toggle these with the play button (there is no actual point in using a second stop button)....
      label contents can't be changed by a button. You can set a label with "gone" and add a new window(locked to main) on the same place that contains only a "remaining" time label and then toggle that window with a button....
      and i think that you can set up a skin window to be displayed while playing (BestRip has done it a few times with "paused")....
