DAP is very slow :(
    DAP is very slow :(
    My DAP is very slow.
    I know it is because i have more than 21.000 tracks in my music collection but i don't like is to remove the tracks...
  • Razgo
    • 2532
    when you say slow, what is it you are doing when it goes slow?
    playing slow?
    slow to select track or?
      Exactly, the whole computer reacts slow when I for example On Starts click it takes about 15 seconds before the start menu appears. Or when I press Next track in DAP it takes even about 15 seconds before the next track is loaded.
      When I close DAP the start menu appears in 1 second.
      I have a Pentium III 350 with 128MB RAM which I only use for DAP and I have Beta 3 of DAP.
      playing slow?
      • Razgo
        • 2532
        ok, Spoon would be able to know what's going on there now. in my viewpoint i think it's simply the size of your collection. with a smaller collection it all runs fast and fine? if so then dap must need a lot more cpu and memory grunt to run 21000 music files in a collection in MMC.
        i have only run up to 8000, and it was fine.
          Yeah, with 1200 numbers it runs fast.
          thanks for your help.
            Perhaps a Skin you are using (with lots of displays)?
            It shouldn't matter if you have 100,000 tracks they are not loaded in memory (only when MMC is opened)>
            • Razgo
              • 2532
              well that's good to know.
                Re: DAP is very slow :(
                YEAH!!
                When I switch to a simple skin instead of mij own made skin my PC is much faster.
                Only opening MMC takes 35 seconds, Edit Tag from 1 track it takes even 35 seconds to display the tag info from the track.
                Thanks for the skin tip.
                I use a full screen skin that show's big the track name, artist name, remaining track time and 2 VU meters.
                Do you have any idea how I can make that without it takes so much from my PC?
                  I am guessing it is just the VU meters that is causing the slowness, try removing them just as a test.
