I have exactly the same problem
  • djben
    • Jul 2003
    • 23
    I have exactly the same problem dnewtype, spoon help us
    I have the Microsoft Wireless multimedia keyboard and in microsoft driver's you can change the master volume with the volume button on your keyboard, then a little green graphic is shown to show you the percentage of the master volume.
    Well, now, with DAP, even when DAP is closed, the little green graphic is shown, but doesn't change if we press the +/- volume button...
    Help us, I will try with DAP 2 again, but I think it has the same problem as with DAP 3 beta 3
    help us, spoon, please... :smile2:
    ps : your program is great, and I'm proud to be one of the beta tester
    • 46220
    It could be the dll is staying in the system after a load, I will note it down as a bug to look into.
    • djben
      • Jul 2003
      • 23
      maybe a dll is not closed, but for sure the programm amp.exe, is done in the taks manager (ctrl+alt+del), I don't see any other explication, but of course I'm not a programmor....
      If you want some more details for this proble, contact me, since I have this problem too...
