Annoying noises when playing Ogg with dAP
  • RossRoy
    • May 2003
    • 403
    Ok guys, someone must have an answer!
    I am running SetiAtHome (the command line version) on my home computer.
    If I try to listen to music using dAP while at the same time running Seti, I can hear crackles, pops and noises in the music as it plays. As soon as I turn off Seti, everything is back to normal. What gives?
    I already checked the priority levels and Seti in at low while dAP is at high, so no problem there.
    I am running WinXP Pro Service Pack 1.. My sound card is a Sound Blaster Audigy running latest web drivers using SPDIF digital output to a decoder. I have 512Meg of RAM, and the CPU is a 1GHz Athlon T-Bird... shouldn't be any problem there.
    The audio files are Ogg Vorbis 256kpbs.
    I really don't know what's going on, somebody must be able to help? Thanks!
    Perhaps hardware interferrance from driving the hardware?
    How often are the pops & crackles?
    • Razgo
      • 2532
      i just tested it, seti does interefere with dap. but it's on any format not just ogg. and i haven't investigated any further than that yet.
      • RossRoy
        • May 2003
        • 403
        I've tried it with WinAMP and WIndows Media Player too now.
        WinAMP does the same thing, cracks for about 0.5 seconds every 3-4 seconds
        WMP is affected too. And there is no difference no matter what priority level I set it at, same goes for Winamp and DAP.
        I just tested by converting a single file to MP3, and that MP3 did it again.
        What soundcard have you got Razgo?
        • Razgo
          • 2532
          mine is a sounblaster live value! card.
          • RossRoy
            • May 2003
            • 403
            Could it be a problem only with soundblaster cards? Mine being an Audigy... hmm
            I've read somewhere that Creative's got very crappy driver support.. Maybe that's the problem?
              You can get rid of creative and install kx drivers:
              • RossRoy
                • May 2003
                • 403
                Problem fixed!
                I installed the Audigy2 drivers on my Audigy soundcard. Works like a charm! Performance is drastically improved, and every utility of the Audigy2 works very well on an Audigy :D
