Uninstall DBpowerAmp Audio Player
  • dj_hitman
    • Feb 2003
    • 34
    How Can I Uninstall the DbpowerAmp Audio Player? I have tried to remove it through the add/remove program inside of windows this does not work. It does not work in my machine or I've got to uninstall it before I can reinstall it... Any suggestions on how to uninstall it? PLEASE HELP!!!!!:headbang:
    How does it not work? try installing a newer one over the top without uninstalling, then if you want the uninstall should work.
