Loss of keyboard control
  • gatorbait
    • Jun 2003
    • 11
    Frustrated--:headbang:
    Decided that I wanted to define some keys to control volume up/down. Found the config. file and opened the keyboard control files.
    The hot keys that came with the software worked initially, but when I assigned two additional keys for volume control, all of the keys failed to work. Can't seem to restore default settings either.
    Any idea of what to do to restore the default keyboard settings? Even more puzzling, the letters X B Z C V still appear in the keyboard control file, but when you press the keys, nothing happens.
    Is there documentation anywhere that might answer my questions?
    TIA,
    Gator
    Start >> Programs >> dBpowerAMP >> Configuration >> Keyboard Control
    • gatorbait
      • Jun 2003
      • 11
      THX
