EQ frequencies settings
  • Razgo
    • 2532
    Hi Spoon, i think you may have answered this sometime ago?
    Just wondering how I can figure out what the frquency range is on the EQ. as in what frequency is the range for each slider and in what increments do they move in?
    thanks.
  • Razgo
    • 2532
    ah, it's been a while since i used the default skin.
    I can see the range now.
    so what do the figures along the bottom represent?
    like the first figure that says 60, is that .60 KHZ? so it would bring out any sounds that are withinn that range I guess.
    actually i think it's self evident now :rolleyes:
    i was just going to make use of the 20 band EQ and make some pre sets. it's all Narlers fault anyway :nospeak:
      I think someone pointed out that the frequencies are a little off, it should be 60Hz, I intend to look at it one day and also make an option for those with a 24 bit sound card - to take the 16bit input, convert to 24 bits so can scale well on the equalizer.
