auto - eq genres
  • donny
    • Oct 2002
    • 761
    auto - eq genres
    Does the auto eq function work for genres?
    I've saved one for Rock but I think it doesn't work
    If you reset the Eq and switch it on, then when something Rock is played it should jump to the settings you saved.
    • donny
      • Oct 2002
      • 761
      Okey I did what you said and now it works ...
      don't know what I was doing wrong...
        Perhaps the eq was not switched on, it only auto selects if it is switched on.
        • donny
          • Oct 2002
          • 761
          Yeah I guess that was it
