Trial Period?
  • dpraptor
    • May 2003
    Trial Period?
    Hi All,
    I just got a message saying my trial period just expired. I think I installed the power pak, so I uninstalled dbM, and downloaded the latest version. When I set it up, I was not able to connect to the net to upload CD info. Was this part of the power pak that I lost?
    Thanks for your help!
  • biboun
    • Nov 2002
    • 35
    I think you can download cd info if you've not installed the power pack.
    Excuse me for my english
    You can correct my mistakes in a ps:
    Help me to improve my english.
    Thank you
    • dpraptor
      • May 2003
      Thanks for your help biboun, I will reinstall and try it again. Is anyone else sure of this answer? How about the moderators??
      Thanx!
      • Razgo
        • 2532
        I have been using the power pack for so long i wasn't sure myself.
        so i uninstalled it and freedb was still there.
        when you say you uninstalled dbm , did you mean dmc? as you would have only needed to uninstall dmc powerpack not dmc.
