Auto Volume Normalization
  • Nicou
    • May 2003
    Hi all!
    I'd like to use the Auto Volume Normalization because the volumes of my mp3s are very various... How does it work ?
    Thanks in advance (and sorry for mistakes...)
  • Taz
    • Mar 2003
    • 9
    If I understand it correctly, the program will remember the max level for the song (stores it in the database) AFTER it has played, and will play it "normalized" after that.
    You will also notice the green A is no longer highlighted after the song has been played and normalized, and the level indicator will adjust itself as well if needed.
