Amp exe problem in Task Manager
  • sloppyjoemusic
    • May 2006
    Hi-
    New computer w/ Windows 7 is acting slow, so I open the task manager & see that in the "Processes" tab there are about 30 listings for "Amp.exe.32" - most using zero cpu, but each about 772 of memory BUT the top listing is using 26% of the CPU - this with the player closed.
    Any suggestions?
    Thanks!
    Re: Amp exe problem in Task Manager
    There should not be 30 amp.exe running, only 1, what did you do (such as clicked on files, etc) to get them running?
    • sloppyjoemusic
      • May 2006
      Nothing special - just spend a few hours listening to music - opening & closing the player.
