Direct connection to hifi versus Squeezebox
  • RussellRay
    • Aug 2004
    • 56
    Hello all
    I run two hifi systems in our house - upstairs and downstairs -
    middle price range, nothing really expensive or very high-end,
    both with similar Kenwood integrated amps.
    1) upstairs - direct connection from my work computer to amp
    - from Realtek soundcard lineout
    - via 3.5mm jack to red/white RCAs on the amplifier AUX
    2) downstairs - via WLAN and a Squeezebox-3 Classic
    I have all my music carefully tagged and well organized.
    Upstairs I use dbPowerAmp's Music Collection (MCC).
    I just select a track or album and off we go. I really like this.
    So long as the files are well tagged, this is clear, simple, and quick.
    Downstairs I have to use the Squeezebox menu.
    I don't like this at all.
    It is muddled and seems to have a mind of its own.
    There seems to be no way to simplify and reduce it.
    I have to navigate through numerous menu items I never need
    to reach the few that I want.
    However, I think the sound quality provided by the SB is better
    than the direct connection provided by my soundcard.
    Question 1 :
    Can someone explain - in simple terms - the difference in sound quality ?
    What does the SB have that the soundcard doesn't ?
    Question 2 :
    Is there some piece of equipment that I could insert in the upstairs system
    that would enhance sound quality in the same way,
    i.e. is there an alternative to the Squeezebox ?
    Can a really good soundcard provide the same quality ?
    Best regards from Ray
    Re: Direct connection to hifi versus Squeezebox
    You could buy a better sound card for the PC - m-audio do some good ones.
