Whats going on?
    Whats going on?
    Why is it that when I select a file to play in Explorer dbpowerAMP decides to play something I decided not to listen to half and hour earlier? There seems to be a queue created whether I like it or not. Sorry if I seem a bit grouchy but I don't like software that won't do as it's told.
    Have a look in 'My Music Collection' the bottom half, that shows if anything is queued.
      Thanks for your reply. I already found the queue window, but I don't want to queue. I just want to play the files I select. How do I disable queuing?
        If random play is off and the queue section is empty it should only play the files you start, if you start a file and it does not play it, then there must be an error with the file, or the codec is not installed.
