playlist sort order
  • sbarrack
    • Feb 2003
    playlist sort order
    i am brand new at this, but this seems to be a great app. after successfully installing the flac codec, i am able to rip a cd into flac files. when i put these files into the playlist, and select sort by track number, they sort instead in the order in which they reside in my directory on the hd. the edit tag info shows the correct track numbers, but the sort is not picking up that information. i know i can move them manually, but it is not sorting as i expect it.
    I will have a look at it, I suspect it is a bug (I saw something similar the other day) - check out the next beta when it is out.
