Tracks were not added...
  • kweller
    • 175
    This is driving me up the wall :headbang:
    I've 'converted' just under 7k tracks to the root of my mStation drive using Sveta. I create a new mmc so I can arrange them then add tracks or folders (makes no difference).
    The db is empty but dAP tells me 'Tracks were not added because they exist already' then 'Tracks could not be added - possibly because of lack of disk space'. If I try to add music from another drive it's fine.
    There's 30Gb free on the disk containing the db and 4.5Gb free on the disk containing the MP3s.
    I've tried reinstalling, uninstalling then reinstalling, going back to beta 3, creating the mmc on a different disk, overwriting an old mmc, creating new ones of different names...none make any difference.
    I then installed dAP on another machine and started adding the music from the problem drive over the network. Other than it's very slow it's working fine.
    I assume something is corrupt that uninstall doesn't remove. Any ideas before I shoot the PC?
    Kevin
  • kweller
    • 175
    [Grimaces] I've just copied some tracks into a sub-directory on my main music drive. Started a new mmc and attempted to add them - same problem.
    So I thought I'd install a fresh instance of dAP on to a different drive on the same machine and see what that did - no difference
    I then spread copies of MP3s in various folders on various drives including those networked from other machines. dAP exhibits the same weird behaviour when I try to add any any of them.
    It will only add tracks to new mmcs that already exist in my primary mmc. :confused:
    Kevin
      out of space error
      Hello,
      I ran into the same problem, but solved it by configuring dBPowerAMP to not try to modify or move new music files. It seems to work fine now.
      Timothy
      nahua@crosswinds.net
      • kweller
        • 175
        :shocked: [stunned silence] What an absolute prat I am!
        I'd forgotten I set dAP up to do that as an experiment and it completely explains the symptoms. :o
        [a few mnutes later] Yep, that's sorted it. So it's not the PC I have to shoot it's myself!
        Thank You :smile:
        Kevin
