Usually When I alter a field in DAP (genre, artist, etc..) I find that the tag information in the actual file is updated as well, but this is not always the case. It seems that if I alter certain files (say I update the genre to "rock" where originally that field was empty), then I try the "refresh from ID tag" then the genre field becomes empty again. Even if I try the "rewrite ID tag" before clicking the "refresh from ID tag" the same thing occurs.
The wierd thing is that if I alter the fields using some other software (either winamp or by using DMC with the utility codecs) then the fields will update, but if I try the "refresh from ID tag" button then nothing happens, but if I remove the file from the database then scan it in again, then it will - at last - be updated with the correct data.
This only happens on certain files.
I can workaround it, but it takes a long time, perhaps someone can think of a better workaround (I was considering using the "ID tag update" utility codec on all my files, but I am nervous to do so, especially when only a few hundred files exhibit this problem).
