Logitech Itouch audio controls and dAP
  • tlanter
    • Jan 2009
    I have recently started using dAP (r2) and noticed that when I exit dAP and try to use I-tunes or Windows Media Player that function keys such as mute, stop, play/pause, and the volume wheel of my Logitech Itouch keyboard will not operate until I reboot. Anyone noticed this same issue?
  • donny
    • Oct 2002
    • 761
    Re: Logitech Itouch audio controls and dAP
    Yes, this is normal. DAP had a feature to automatically pick up these keys in the system. I think the only way to go around it is to rename "dAPKeyControl.dll" in the dbpoweramp directory. After a reboot it will not take over the keys anymore...
    And you can still program those Ctrl+Alt+something in the keyboard shortcuts options.
    • tlanter
      • Jan 2009
      Thank you Donny, that solved the problem. You just made my family very happy. Have a good week, whats left of it (I know its about 3:45 AM Thursday in Serbia). Best regards. Terry
