no audio
  • roma0926
    • Sep 2006
    • 19
    no audio
    i just installed db 2.0 with monkey audio codec. off mmc everything is fine. however, when i put a cd in to play vista sends up an error message "Amp has stopped working" and i can't get it to play a cd. how do i get it going again?
  • Wayne
    • Aug 2002
    • 1254
    Re: no audio
    I'm not sure if dAP is compatible with Vista.
    BTW which version of vista are you running?
    • roma0926
      • Sep 2006
      • 19
      Re: no audio
      the cd player did work but when i added .ape codec it suddenly would not. the vista error message just says amp has stopped working and cda.dll is the fault module. i am using vista home premium.
        Re: no audio
        Which ape codec did you add, the one from Codec Central or the one from Legacy Codec Central?
