switching problem
  • kakagi
    • Jan 2008
    • 8
    switching problem
    hi....
    lately a new "problem" has popped up. when the player is up with the equalizer shown and i try to switch to another window the equalizer still shows in the current window. this happens with the default skin and studio pro II which are only 2 skins i have / use.
    if i use the minimize button or if i click the task bar icon twice it will minimize the player and the eq. but if i use the alt-tab to switch windows the equalizer stays up... this dosn't happen with just the player up.
    any ideas?
    tia
    k
    Re: switching problem
    What version of dAP are you using?
    • kakagi
      • Jan 2008
      • 8
      oops... release 2
      xp w/sp3 2.33ghz core2 2gb ram
      • kakagi
        • Jan 2008
        • 8
        tried to reinstall, no joy.
        updated to R3 b6, same problem.
        kinda weird..
          I wasn't aware of this previously but I can confirm the existence of this. However, it seemes to be ver strange. At first this occurred as described with every skin I tried at first (Default, GoldenAMP, Black Beauty and, in a strange variant of the problem with the BestRip CDred) until I tried the Beyond skin by Donny (which worked properly). Then I tried the 3D Wood skin (which also worked properly) and the BestRip CDAlyssa skin (which worked despite seeming to have the same basic design framework as BestRip CDred). So then I went back to the BestRip CDRed skin and that worked properly. So then I retested the skins that showed this problem and they all worked OK also.
          When I turned dAP off and re-booted, the problem occurred again but disappeared after I tried the 3D Wood skin. Then the skins that I had tried worked properly again.
          I again turned dAP off and restarted it. The problem occurred again with a few skins until I tried the Beyond skin. That skin worked and after this the other skins I had tried worked OK again.
          It appears that there is some obscure registry setting that is mis-set for some skins in a way that results in the EQ remaining when alt-tab is used to minimize dAP. It appears thaat not all skins feature this problem and that once one of these skins is used the registry setting re-corrects for all the other skins until you turn dAP off. Go figure.
          Bill
          • donny
            • Oct 2002
            • 761
            This really is a weird conlcusion. I know there were some similar bugs in some older versions of dap, where there were problems with window drawing in certain circumstances, but not like this.
            I was not able to repeat this behaviour, though I tried to turn on and off dap in different settings. Which should mean there is something else connected with it.
            Good tests Xoas
