Play Audio CD - no manual for dummies?
  • catch22
    • Jul 2008
    "Play Audio CD" is something that came along with the software install - good thing, cause I didn't find a cd-player yet that works good with my difficult soundcard.
    I don't see how to work it though; I have to go back to Explorer every time to click for getting the next track to play.
    Also directly adding songs from the music library (without opening explorer) to an existing playlist remains a mystery.
    Re: Play Audio CD - no manual for dummies?
    First, what version of dAP are you using? See "Need to find your version" below to discover your version
    • catch22
      • Jul 2008
      Originally posted by LtData
      First, what version of dAP are you using? ...
      dBpoweramp Audio Player
      Right-click on a blank part of your skin to bring up the menu. If it says "dBpoweramp", you have release 2.
      So it must be release 2 for me.
        Try upgrading to the beta r3 and see if that helps any. Link is below in my signature.
        • catch22
          • Jul 2008
          I upgraded but it doesn't change the situation; am I overlooking 2 obvious?
          I put in a cd - click play button - it works
          I skip - it works
          I wait for the next track - it doesn't play automatically :thumbdown
          IOW there's no continuos play
          Also, I don't see a list of the track numbers of the cd to pick from.
