Please explain Shutdown for me
  • Lithp
    • Jun 2002
    • 15
    Sorry. This is probably a dumb question but I cannot figure out how to play music and then have the computer shut down automatically. I have control freak, DMC, and shutdown installed. What am I doing wrong?
    You don't mention dBpowerAMP Audio Player? you would have to have that installed, then have a look in 'C:\dAPControl' there are files there - when played they will shut down the computer. So you might create a playlist with one of those files at the end.
    • Lithp
      • Jun 2002
      • 15
      Thank you for your reply Spoon. I will test this out and report back.
      As far as not mentioning dbpowerAmp Audio Player - well I thought that was a given. After all everyone is using it. Or should be by now.
      Nothing is better.
      Thx,
      Lithp
