audio cd
  • Baloe
    • Apr 2003
    • 95
    audio cd
    When trying to play a audiocd my computer crashes. When i use :Program FilesIllustratedBpowerAMPAmp.exe" <autoplayaudiocd> from the program explorer it craches. When i use :Program FilesIllustratedBpowerAMPAmp.exe" and then use open music files and then go to the audio tracks on the cd it craches the computer. Any idea why?
    Baloe
    Re: audio cd
    Any program crashes your computer? Check your CD drive to see if it is set to PIO mode, as described here: http://forum.dbpoweramp.com/showthread.php?t=4619
    • Baloe
      • Apr 2003
      • 95
      Re: audio cd
      CD drive is set to ultra DMA 5-ultra 5, let bios select transfer mode.
      Is this any good ?
      Baloe
        Re: audio cd
        That should be fine.
        Do all programs crash when you try to play a CD? If so, can you read data CDs without crashes?
        • Baloe
          • Apr 2003
          • 95
          Re: audio cd
          No, only when i try to play it with dAP.
