Player finds wav but not flac
  • Joe Wilson
    • Jul 2006
    Most of my music is on a NAS device in flac format. When I try to add music to dAP it only "sees" the wav files. What am I missing?
    I just downloaded Reference 12.3 trial yesterday
  • Ciro
    • Jul 2007
    Re: Player finds wav but not flac
    Did you read the LtData sticky post? http://forum.dbpoweramp.com/showthread.php?t=12667
    dAP is NOT compatible with the codecs that dMC r12 uses.
    The best way to solve problems is reading first the sticky posts, second using search, and third posting.
      First, make sure dAP and dMC r12 are installed to separate locations, as mentioned here: http://www.dbpoweramp.com/legacy-compatibility.htm
      Then install the Legacy FLAC codec to dAP's directory.
      • Joe Wilson
        • Jul 2006
        "I'm Beginning To See The Light"
        I actually saw that post but didn't know what to make of it.
        Sorry and thanks
