enqueue and add dissapeared
  • marsopia
    • Aug 2002
    • 13
    I dont know why the Enqueue and Add function disspaeared form the right click in -windows Explorer.
    I re-installed the dBpowerAmMP and re associated the files, but the functiones are not there.
    Any clue?
    Are the files still associated with dAP? ie if you double click them do they play in dAP?
    • marsopia
      • Aug 2002
      • 13
      Enque and add disapeared
      Yes they are, the mp3 files show DAP´s icon and when you doble click them DAP strats playing.
      I discovered yesterday that Enqueue and Add function appear when I right click a folder but not a music file.
      I use Win Me.
        Not much help, but try associating it with other programs and then back to dBpowerAMP.
        • marsopia
          • Aug 2002
          • 13
          I done that beore, but tried again. I associeted with Soniqe, then back to DAP; nothing happened. Later with Winamp, back to DAP, but nothing changes.
          I tried also uninstalling Sonique and reinstalling DAP.
          • marsopia
            • Aug 2002
            • 13
            Enqueue and Add Reappeared!!
            I tired uninstalling every player I had in mi computer and reinstalled DAP and all ths stuff on a new folder:
            C:\Archivos de programa\Illustrate New\dBpowerAMP
            and it worked fine. ¿Registry problems?
            Spoon, your program is wonderfull
              There is a certain black magic when it comes to Windows.
