possible to play instead of enqueue on double click ?
  • BlueScreenJunky
    • Oct 2002
    • 9
    There's something I don't understand : even if I set "Explorer Double Click" on "Play in daP" in the dbpowerAMP File Typ associations options, when I double click on a file quickly after opening another, it enqueues the second one instead of playing it...
    I guess it's more a "feature" than a "bug", but I can't stand this ! I want dAP to work the way I want !!! is there a way to do this ? (I'm using R2 beta 8)
    Oh and still this thing I don't understand but I seem to be the only one : Why are the queue and the playlist to different things ? it would be simpler if you could just save your queue as a playlist, and enqueue all the songs in a playlist when you open it (hope you understand what I mean lol !)
    Yes a 'feature' you need to leave it a few seconds before playing the next.
    • BlueScreenJunky
      • Oct 2002
      • 9
      Ok, so if you could add a check box to turn it on/off it would make me very happy (huh ? more important things to do ???:D )
        If you selected 10 files and clicked Play, Windows calls dAP once for each file, so that is where that 'bug' works for you as it would play the first one and enque the other 9, it was specifically written like that...really I am stuck...
        • BlueScreenJunky
          • Oct 2002
          • 9
          okay, I got it now... maybe you can reduce the delay, because I think it's at least 1 full second as it is now, maybe 100 or 200 ms would be okay.
          But now that I understand why it works like that it's OK, I'll get used to it.
          thanx for the answer.
