WMA codecs do not work
  • peacespotting
    • Apr 2007
    I have the newest version of dbpowerAMP but after installing both the wma10 and wma9 codecs from the db site i still cannot import wma tracks, and the codecs do not appear when i look at the list on the player
    i am using windows xp
    Re: WMA codecs do not work
    You are having a problem with the audio player or the music converter? If you are having problems with the audio player, you must get your codecs from Legacy Codec Central, NOT the main Codec Central. The link to Legacy is in the main Codec Central.
    • peacespotting
      • Apr 2007
      thanks yeah i was using the codecs for the wrong application :blush: , i meant it for the player not converter, it's installed and working now thanks
