Note regarding dMC r13 Compatibility
This topic is closed.
This is a sticky topic.
    dAP is NOT compatible with the codecs that dMC r13 uses. You MUST install dAP to a different location than dMC r13, as stated here http://dbpoweramp.com/legacy-compatibility.htm, and then get codecs for dAP from Legacy Codec Central. The link to Legacy Codec Central is located in the main Codec Central.
    Note: If you have dAP and dMC r13 in separate directories, as you must, you install Legacy Codecs into dAP's directory.
