Multiple Users for Same Music Collection
    Is there any way I can have the Music Collection (editor.exe) to load up a particular mcc file, instead of the one in the DBPowerAmp directory?
    With most programs, you can send a string to an executible with the location of a file to open it up once the app loads (usually inside of a shortcut file). For instance:
    "C:\Program Files\Illustrate\dBpowerAMP\Editor.exe" "C:\Program Files\Illustrate\dBpowerAMP\office.mcc"
    Instead of loading Office, it loads an mcc based off my username.
    I'd like to build a Music Collection on a Mapped Drive so multiple users can add music, edit tags, and their "preference" to a song.
    This leads me to the next question: Where is the "Preference" field stored? In the MCC or one of the other username-based files?
    The active one is set in the registry:
    HKEY_CURRENT_USER\Software\Illustrate\dBpowerAMP
    You can create a new MMC of say SomePath\123.mmc, then set every one to use that.
    Everything to do with a Music Collection is saved under the user filenames.
