Player interrupted!
  • Antti
    • Oct 2006
    Player interrupted!
    I have a problem with my dBpower AMP player: whenever I open an application the player does not work properly. It seems that the CPU leaves it unsupported during the time e.g. Word is opened. This problem arised when I used optimizer programs problems to make my XP work faster. Well, Windows XP works faster now but at the expense of not supporting fully my AMP player at all times.
    The problem is not specific with the dBpower AMP player; it occurs with other players too. The priority of the player is "high" so it should be OK. I'm wondering if it is possible to increase buffering of the player? How to do it?
    Any ideas?
    Regards,
    Antti
    Finland
    Re: Player interrupted!
    Buffering will not help (dAP will buffer for 2 seconds in advance in any case), if you open a program then it should stop playback 2 seconds later.
