Error play 24bit 96kHz FLAC
  • Lt.Worf
    • Sep 2005
    • 33
    Hello,
    when I play a 24bit 96kHz WAV file it sounds ok, but the same as FLAC sounds very bad - like playing at half speed or so.
    Playing the same FLAC file in Winamp is ok.
    Is there a problem with the FLAC decoder ?
    Thanks for help.
    audio player 3b6
    music converter 11.5 registerd power pack
    FLAC release 5.5 version 1.1.2
    Re: Error play 24bit 96kHz FLAC
    There is no flac 5.5? it is 5.3, check you have the latest as there was a bug with 24bit decoding in older versions.
    • Lt.Worf
      • Sep 2005
      • 33
      yes, its version 5.3.
      sorry
      P.S.
      I converted the file to 24bit 48kHz FLAC and it works.
      So I think 24 bit works but there is a problem with 96kHz files ? Or is there an incorrect header in my wave file (but no problem in winamp) ?
        It could be your sound card cannot open an audio stream with 96KHz unless a waveformatextensible header is supplied (which dap will not do). Or it could be that winamp is playing through directx which is resampled down to 44.1khz by windows.
        • Lt.Worf
          • Sep 2005
          • 33
          I configured dap to play with directx too, but its the same problem.
          Winamp plays correct with "direct sound output" and wave out.
          P.S. My sound card (Terratec Aureon Space 7.1) is connected via SPDIF and analog to my surround receiver. With SPDIF it shows 48kHz.
