how to split tracks from full dl album
  • jacsis
    • Oct 2002
    I have several full albums I downloaded from winmx, but I dont know how to seperate the tracks ...can anyone out there help me?:headbang:
  • Clete
    • Aug 2002
    • 30
    Check this out. I have used it to split MP3's
    • jacsis
      • Oct 2002
      dont know how to do it....
      Please help me, I dont know how to do it and cant figure it out either......I know it is a bother but could you walk me step by step?:headbang:
      • Clete
        • Aug 2002
        • 30
        It takes a little practice. Input file is your album. Output is track name. Set Begin is the start of each track. You can play the track and stop it setting the end of the track at the time you want. I think you can use the Get End button. You can then cut the track and save it. Repeat for each track. I had to fiddle around with it to get the right results. It does not change your master because you can only save the output file. The documentation is pretty good too. Good Luck.
        If you want something simpler try this site http://www.codevisions.de/
        It has a basic MP3 file splitter ( by size or time (preserving ID tags)).
        • jacsis
          • Oct 2002
          Hi Clete and Thanks for all your help. I tried to get that link to work and got to the web site but I cant get the download. I saved it and will try from time to time again to see if I can get it.
