Problem with db hiding ?
  • mcgirt
    • Jun 2006
    Hey there, I tried searching before I posted and didn't find an exact match with my problem.
    (using windows XP)
    I just started using the mini control bar, and my nephew slapped the keyboard :o ... after that I couldn't put my mouse on the controller- the mini would move ahead of my cursor. As I ended up trying to close my other applications, the mini player eventually went BELOW windows taskbar. I restarted DB. I restarted XP. It still stays there (when I click on it now, it flashes for a second then goes under again). I went to install options and worked okay from the taskbar, but I want to see the whole thing (like album name, etc)
    ..ugh, is a re-install in my future?
    Re: Problem with db hiding ?
    Easier than a re-install, but almost the equivalent. See here about resetting dAP to facotry defaults: http://forum.dbpoweramp.com/showthread.php?t=403
    • mcgirt
      • Jun 2006
      Excellent results!
      Thanks! :komisch12
