Are you using the dAP release 3 beta or release 2? To check, right-click a blank spot on the current skin. If you see "release 3 beta x" on the left-side of the menu going upwards, you have the latest beta. Otherwise, download the beta at the link below. Even though it is a beta, it is perfectly stable.
