Guide to trying Beta dB AP Rel 3 ?
  • Puterman
    • Sep 2004
    • 11
    Is there a Guide to trying Beta dB AP Rel 3. If so where?
    Questions :
    1. Can I install over dBpowerAMP Audio Player Release 2 or do I need to uninstall Rel 2 first?
    2. Then do I need to upgrade Converter and Sveta in order for them to be compatible or will the older versions work with newer Beta?
    Re: Guide to trying Beta dB AP Rel 3 ?
    The dAP beta 3.6, which has been out for more than a year should be compatible with Sveta and dMC (Music Converter) as is. I believe you can install it over dAP r2 although you may be instructed to first uninstall dAP (which you would then do).
    Bill
