2 problems - related? - amp vs. power amp
  • sloppyjoemusic
    • May 2006
    1. When I right click on audio files I get 2 choices under the "open with" option. One is "Amp" the other is "dbpower AMP Audio Player". I have a feeling that this isnt right, and might be confusing my player. Is there a fix for this?
    2. I cant get flac files to play consistantly. This includes foles covirted w. your converter. I have installed the codec, and they have played at times, but double clicking on a flac file doesnt make it play. Are there explicit directions for how to install codecs? I have never had troible with that inthe past, but want to make sure I did it right. Any other suggestions?
    THANKS IN ADVANCE
    • 46169
    Re: 2 problems - related? - amp vs. power amp
    I am not sure that we put amp in the right click menu, it is possibly something else.
    Make sure you have your FLAC codec installed to the same location as Music Converter and Audio player.
