clean PrevPlayed.exe
  • Baloe
    • Apr 2003
    • 95
    How can i clean the list of PrevPlayed.exe?
    Baloe
  • dbample
    • Oct 2002
    • 69
    Re: clean PrevPlayed.exe
    Last played can be cleared by deleting 'YourMusicCollection.Previously Played', according to Spoon from this thread:
    if that's what you are asking.
      On my installation, running dAP, the file seems to be labelled Owner.Previously Played.
      This can be found going My Computer>Drive letter>Program Files>Illustrate>dBpowerAMP and it is a separate file there.
      You can open it with notepad, go to the Edit menu, Click Select all and click delete.
      Bill
      • donny
        • Oct 2002
        • 761
        yes the file is named username.prevplayed on multi user systems (like windows xp)
        on single user systems (like win98) I think it is called default or defuser or something like that, can't remember.
