Recording with Auxiliary Input
    How do you record both sides of a LP on track 1, so you end up with only one File for both sides of the Album?
    No ideas spring to mind, unless you want a gap whilst you swap the record over...
      You might be able to put both sides of an LP on one side of an audiotape and then use DMC auxilary input to copy the taped version as a single track.
      best wishes,
      bill mikkelsen
      • daren
        • 153
        Record two linear WAV files (one for side A and one for side B)
        and use an editor (e.g. Cool Edit) to stick the two together and
        save as one WAV file.
        This one file could then be converted to any other format using
        dbpoweramp music converter.
        Hope this helps,
        Daren.
