Foobar music folder not transfering
  • Arleene
    • Feb 2023
    My ultimate goal is to get rid of iTunes in favor of another music library. I installed Foobar 2000 on my PC because of its ability to transfer to both ios and android devices. Once I populated my Foobar library and tried to sync, it said to install TuneFusion, which I have done. So now, as I have started to sync my music, TuneFusion is only pulling from the iTunes library which is exactly what I don't want to do. How do I get TuneFusion to recognize the Foobar library and only transfer that music? I am currently trying to transfer to an iPhone. Step-by-step directions will be needed as I am not savvy when it comes to all this digital stuff.
    • 6189
    Re: Foobar music folder not transfering
    it will pull from whatever directory you set in TuneFusion for the source files. I assumed you copied your files that itunes is using to another directory on your computer. So just point TuneFusion to that directory.
    edit: and note that iTunes points at a directory holding your files. Foobar2000 points at a directory holding your files. And any other music server/player can point to that directory of files. You can have a single directory of files that is used by different music servers.
