TuneFusion crashes on macOS Ventura 13.1
  • Miner2049er
    • Oct 2019
    • 10
    Hello,
    TuneFusion opens but after approx. 5 seconds it crashes. It's the same with every try! Any ideas what's wrong / how to fix?
    Happy Holidays!
    • 1654
    Re: TuneFusion crashes on macOS Ventura 13.1
    Hello and thanks for your bug report.
    Please follow steps documented here-
    To review recent crashes from your system: Open 'Console' app (Launchpad / type 'Console'). Go to 'Crash Reports' section, look for relevant entries there. To locate the crash report data file, right click the entry and choose "Reveal in Finder". Please attach the file when contacting dBpoweramp tech
    Send crash report data to peter@dbpoweramp.com for analysis.
    Also:
    What kind of syncs did you use?
    In Finder, please (cmd+shift+g) open ~/Library/TuneFUSION, look for Logs-NNNNNN folders - it would be helpful if you could post contents of log files present there - just the newest ones if there's lots of them.
      • 1654
      Thanks for the details.
      Crash fixed in new beta-
      Current version: beta 4 Download: https://www.dbpoweramp.com/beta/TF-R18b4.dmg Changes since 1.7: Workaround for file-busy & operation-timed-out errors when syncing. Changes in beta 2: Additional workaround for file busy errors. Changes in beta 3: Mitigated crashing when scanning for music in a folder with too
      Also, I'd like to know what kind of music folder structure you use? This info isn't written in logs as I never thought we'd run into a problem due to such.
      To trigger this crash, it takes a *long* chain of subfolders: folder1/folder2/folder3/folder4/folder5/.... in your music folder.
      • Miner2049er
        • Oct 2019
        • 10
        Works - thank you!
